Pioneer Steel Wheels Swivels Replacement
  1. Pioneer Steel Wheels Swivels Replacement, Folding Hinges: step 1, image 1 of 2 Pioneer Steel Wheels Swivels Replacement, Folding Hinges: step 1, image 2 of 2
    • While holding the base of the headband with one hand, hold the ear cup with the other hand.
    • Pull them apart to reveal the screw.
  2. Pioneer Steel Wheels Swivels Replacement: step 2, image 1 of 2 Pioneer Steel Wheels Swivels Replacement: step 2, image 2 of 2
    • While apart, remove the screw from the headphone.
  3. Pioneer Steel Wheels Swivels Replacement: step 3, image 1 of 2 Pioneer Steel Wheels Swivels Replacement: step 3, image 2 of 2
    • Loosen the plastic cover piece that protects the chrome folding hinge.
    • Remove the plastic cover piece.
    • During reassembly, make sure the plastic covering piece hooks onto the base of the chrome hinge before screwing it back in.
  4. Pioneer Steel Wheels Swivels Replacement: step 4, image 1 of 2 Pioneer Steel Wheels Swivels Replacement: step 4, image 2 of 2
    • Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge.
    • Repeat for the opposite side if necessary.
  5. Pioneer Steel Wheels Swivels Replacement, Drivers: step 5, image 1 of 2 Pioneer Steel Wheels Swivels Replacement, Drivers: step 5, image 2 of 2
    • Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver.
  6. Pioneer Steel Wheels Swivels Replacement: step 6, image 1 of 2 Pioneer Steel Wheels Swivels Replacement: step 6, image 2 of 2
    • Pull the driver cover away from the headphone.
    • Do not pull the driver cover away too fast since there are wires connecting the driver to the ear cup.
    • During reassembly, make sure the two wires are pointing downward before screwing the driver back in.
  7. Pioneer Steel Wheels Swivels Replacement, Swivels: step 7, image 1 of 2 Pioneer Steel Wheels Swivels Replacement, Swivels: step 7, image 2 of 2
    • Separate the swivel from the ear cup.
  8. Pioneer Steel Wheels Swivels Replacement: step 8, image 1 of 3 Pioneer Steel Wheels Swivels Replacement: step 8, image 2 of 3 Pioneer Steel Wheels Swivels Replacement: step 8, image 3 of 3
    • Grab the end of the swivel that is closest to "Pioneer" and pull outward.
  9. Pioneer Steel Wheels Swivels Replacement: step 9, image 1 of 3 Pioneer Steel Wheels Swivels Replacement: step 9, image 2 of 3 Pioneer Steel Wheels Swivels Replacement: step 9, image 3 of 3
    • Switch sides and grab the other end of the swivel and pull outward as well.
    • During reassembly, insert the swivel back at the tilted position so it can be popped in with ease.
Garrett Leung
955 Reputation
8 Guides authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
37 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 325
