Pioneer Steel Wheels Folding Hinges Replacement
  1. Pioneer Steel Wheels Folding Hinges Replacement, Headband: step 1, image 1 of 2 Pioneer Steel Wheels Folding Hinges Replacement, Headband: step 1, image 2 of 2
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Folding Hinges Replacement: step 2, image 1 of 2 Pioneer Steel Wheels Folding Hinges Replacement: step 2, image 2 of 2
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Folding Hinges Replacement: step 3, image 1 of 3 Pioneer Steel Wheels Folding Hinges Replacement: step 3, image 2 of 3 Pioneer Steel Wheels Folding Hinges Replacement: step 3, image 3 of 3
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
  4. Pioneer Steel Wheels Folding Hinges Replacement, Folding Hinges: step 4, image 1 of 2 Pioneer Steel Wheels Folding Hinges Replacement, Folding Hinges: step 4, image 2 of 2
    • While holding the base of the headband with one hand, hold the ear cup with the other hand.
    • Pull them apart to reveal the screw.
  5. Pioneer Steel Wheels Folding Hinges Replacement: step 5, image 1 of 2 Pioneer Steel Wheels Folding Hinges Replacement: step 5, image 2 of 2
    • While apart, remove the screw from the headphone.
  6. Pioneer Steel Wheels Folding Hinges Replacement: step 6, image 1 of 2 Pioneer Steel Wheels Folding Hinges Replacement: step 6, image 2 of 2
    • Loosen the plastic cover piece that protects the chrome folding hinge.
    • Remove the plastic cover piece.
    • During reassembly, make sure the plastic covering piece hooks onto the base of the chrome hinge before screwing it back in.
  7. Pioneer Steel Wheels Folding Hinges Replacement: step 7, image 1 of 2 Pioneer Steel Wheels Folding Hinges Replacement: step 7, image 2 of 2
    • Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge.
    • Repeat for the opposite side if necessary.
Garrett Leung
955 Reputation
8 Guides authored
Cal Poly, Team 10-40, Amido Spring 2013 Member of Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Members
37 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 482
