Pioneer FH-X730BS Disk Drive Replacement
  1. Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: step 1, image 1 of 3 Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: step 1, image 2 of 3 Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: step 1, image 3 of 3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS Disk Drive Replacement: step 2, image 1 of 1
    • After removing the stereo face from the frame, it should look similar to this.
  3. Pioneer FH-X730BS Disk Drive Replacement: step 3, image 1 of 1
    • Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
  4. Pioneer FH-X730BS Disk Drive Replacement: step 4, image 1 of 3 Pioneer FH-X730BS Disk Drive Replacement: step 4, image 2 of 3 Pioneer FH-X730BS Disk Drive Replacement: step 4, image 3 of 3
    • Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
  5. Pioneer FH-X730BS Disk Drive Replacement: step 5, image 1 of 3 Pioneer FH-X730BS Disk Drive Replacement: step 5, image 2 of 3 Pioneer FH-X730BS Disk Drive Replacement: step 5, image 3 of 3
    • Unscrew the four inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate.
    • Replace the old disk drive with a new one.
Cody Pesta
688 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 323
