Pentax PZ-10 Back Cover Locking Switch Spring Replacement
  1. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Bottom Cover: step 1, image 1 of 1
    • With the lens face up and the bottom panel of the camera facing you, remove the two 7mm screws on the left using the J0 screwdriver.
    • Remove the six 4.3mm screws in the middle and right of the panel using the J0 screwdriver.
    • Pull off the bottom casing to remove.
  2. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing Bottom Casing: step 2, image 1 of 1
    • With the screws removed, the bottom casing should come off very easily by pulling on the casing.
  3. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Back Cover: step 3, image 1 of 1
    • Place the camera on its side so the lens is facing left.
    • Press down on the locking switch on the side panel facing you.
  4. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: step 4, image 1 of 1
    • With the door unlocked, rotate the device to access the bottom.
  5. Pentax PZ-10 Back Cover Locking Switch Spring Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Using a pair of tweezers, gently remove the metal tab securing the back door axle.
    • The door will come loose at this point, watch for any loose parts that may also come out.
  6. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Side Panel: step 6, image 1 of 1
    • Once the back cover is fully removed, remove the two 4.35mm screws attaching the cover of the unlocking switch, and remove the plate.
  7. Pentax PZ-10 Back Cover Locking Switch Spring Replacement, Removing the Spring: step 7, image 1 of 1
    • Locate the spring at the upper left corner of the face, and pull the rings of the spring off of the pins to remove it using plastic opening tools.
    • You are now ready to replace the spring.
Ryan Su
107 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 430
