Pentax Optio WG-2 LCD Screen Replacement
  1. Careful: steps 1-6 are sourced from a guide that's marked as in-progress.
    Pentax Optio WG-2 LCD Screen Replacement, Back Case: step 1, image 1 of 2 Pentax Optio WG-2 LCD Screen Replacement, Back Case: step 1, image 2 of 2
    • Remove all four 1 mm JIS #00 screws from the back of the camera.
  2. Pentax Optio WG-2 LCD Screen Replacement: step 2, image 1 of 1
    • Use your finger to peel the grip off the top of the camera.
    • For best results, start from the right side of the camera, opposite the buttons.
    • Once the grip is removed, you will most likely lose the water-tight seal.
  3. Pentax Optio WG-2 LCD Screen Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to remove the two buttons from the top of the camera.
    • The buttons may fall out while removing the grip.
  4. Pentax Optio WG-2 LCD Screen Replacement: step 4, image 1 of 3 Pentax Optio WG-2 LCD Screen Replacement: step 4, image 2 of 3 Pentax Optio WG-2 LCD Screen Replacement: step 4, image 3 of 3
    • Remove the three 1 mm JIS #000 screws from the top.
    • Remove the 1 mm JIS #000 screw from the bottom.
  5. Pentax Optio WG-2 LCD Screen Replacement: step 5, image 1 of 1
    • Carefully separate the back and the front of the camera.
    • There are three ribbon cables connecting the two boards. Be careful not to tear them.
  6. Pentax Optio WG-2 LCD Screen Replacement: step 6, image 1 of 1
    • Use the tip of a spudger to flip up the small retaining flaps on the ribbon cable ZIF connectors.
    • Carefully pull the ribbon cables out of their sockets.
  7. Pentax Optio WG-2 LCD Screen Replacement, LCD Screen: step 7, image 1 of 2 Pentax Optio WG-2 LCD Screen Replacement, LCD Screen: step 7, image 2 of 2
    Buy
    • Carefully remove the clear tape covering the screws and the ribbon cable.
    • Be careful not to tear the ribbon cable when removing the tape.
    • We want to remove the larger silver panel (right). The best way to do this is to slightly bend the cover backwards and use the tweezers to grab a corner and slowly lift the screen up and out.
  8. Pentax Optio WG-2 LCD Screen Replacement: step 8, image 1 of 2 Pentax Optio WG-2 LCD Screen Replacement: step 8, image 2 of 2
    • Once the screen is removed you should have two pieces as seen in the picture.
    • The screen is the silver rectangle in the top of the picture or the component seen in picture two.
2 other people completed this guide.
Matthew Bessette
658 Reputation
6 Guides authored
2 Comments
Dónde puedo comprar el Display?
Where I can buy the dispaly?
Sebastian Mesa - Reply
opération réussie ça marche nickel la plus grosse difficultée est de remettre correctement les 3 connecteurs
impératif: utiliser les bons outils comme indiqué attention aux vis il y a un petit joint et les longueurs différentes ne pas mélanger !!!
merci pour ce super tuto ….
walchkorn - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 787
