Penguin FZ-8 28” Tower Fan Blade Replacement
  1. Penguin FZ-8 28” Tower Fan Blade Replacement, Fan Blade: step 1, image 1 of 1
    • Flip the fan onto its side so that you can access the base of the fan.
    • Remove the single 11 mm screw using a Phillips #1 screwdriver.
  2. Penguin FZ-8 28” Tower Fan Blade Replacement: step 2, image 1 of 3 Penguin FZ-8 28” Tower Fan Blade Replacement: step 2, image 2 of 3 Penguin FZ-8 28” Tower Fan Blade Replacement: step 2, image 3 of 3
    • Rotate the base of the fan counter-clockwise to detach it from the rest of the fan. The base can be separated into two parts.
  3. Penguin FZ-8 28” Tower Fan Blade Replacement: step 3, image 1 of 2 Penguin FZ-8 28” Tower Fan Blade Replacement: step 3, image 2 of 2
    • Remove four 5 mm screws from the sides of the base of the fan using the Phillips #1 screwdriver.
  4. Penguin FZ-8 28” Tower Fan Blade Replacement: step 4, image 1 of 2 Penguin FZ-8 28” Tower Fan Blade Replacement: step 4, image 2 of 2
    • Remove the two 5 mm screws located on the outside of the case inside the holes using the Phillips #1 screwdriver.
  5. Penguin FZ-8 28” Tower Fan Blade Replacement: step 5, image 1 of 2 Penguin FZ-8 28” Tower Fan Blade Replacement: step 5, image 2 of 2
    • Remove a single 5 mm screw on the outside cover of the fan using the Phillips #1 screwdriver.
    • Gently lift the top cover of the fan halfway to expose the single 5 mm screw. Remove this screw using the same Phillips #1 screwdriver.
  6. Penguin FZ-8 28” Tower Fan Blade Replacement: step 6, image 1 of 2 Penguin FZ-8 28” Tower Fan Blade Replacement: step 6, image 2 of 2
    • Pinch the sides of the case to remove the case from the rest of the fan.
  7. Penguin FZ-8 28” Tower Fan Blade Replacement: step 7, image 1 of 1
    • Remove the single 5 mm screw between the fan blade and the motor using the Phillips #1 screwdriver.
  8. Penguin FZ-8 28” Tower Fan Blade Replacement: step 8, image 1 of 2 Penguin FZ-8 28” Tower Fan Blade Replacement: step 8, image 2 of 2
    • Remove the two 5 mm screws holding the fan blade in place using the Phillips #1 screwdriver.
  9. Penguin FZ-8 28” Tower Fan Blade Replacement: step 9, image 1 of 1
    • Remove the fan blade from the device and clean it off before reassembling your device.
Ethan
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 41
All Time: 928
