Palm Zire 71 Battery Replacement
  1. Palm Zire 71 Battery Replacement, Preparation: step 1, image 1 of 1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Battery Replacement, Top Screws (2) Removal: step 2, image 1 of 1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Battery Replacement, Bottom Screws (3) Removal: step 3, image 1 of 1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Battery Replacement, Front Panel Removal: step 4, image 1 of 2 Palm Zire 71 Battery Replacement, Front Panel Removal: step 4, image 2 of 2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: step 5, image 1 of 2 Palm Zire 71 Battery Replacement, Bracket and Speaker Removal: step 5, image 2 of 2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Battery Replacement, Back Cover: step 6, image 1 of 2 Palm Zire 71 Battery Replacement, Back Cover: step 6, image 2 of 2
    • Slide the back cover off.
  7. Palm Zire 71 Battery Replacement, Battery: step 7, image 1 of 1
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  8. Palm Zire 71 Battery Replacement: step 8, image 1 of 2 Palm Zire 71 Battery Replacement: step 8, image 2 of 2
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  9. Palm Zire 71 Battery Replacement: step 9, image 1 of 3 Palm Zire 71 Battery Replacement: step 9, image 2 of 3 Palm Zire 71 Battery Replacement: step 9, image 3 of 3
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  10. Palm Zire 71 Battery Replacement: step 10, image 1 of 3 Palm Zire 71 Battery Replacement: step 10, image 2 of 3 Palm Zire 71 Battery Replacement: step 10, image 3 of 3
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
7 other people completed this guide.
Jinxian Jiang
245 Reputation
3 Guides authored
One Comment
It's clear they just want you to throw it away when the battery dies. That was quite a chore getting the parts off and such without destroying the circuit board and that fine ribbon cable. Got it done though. No wifi I see. Too bad.
dnphoton - Reply
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 46
All Time: 9,061
