Introduction
This guide will show you how to replace the mother board should the phone completely loose major functionality. The mother board is the key chip that handles all the logistics and processes that comes with using the phone.
First the back panel must be removed to reveal the battery.
Remove the battery pack.
With the backplate removed, we have easy access to the PCB.
Two connectors must be disconnected so that we can remove the PCB.
Gentle prying with the opening tool should easily separate the glued PCB from the rest of the phone.
Once you have removed the PCB, you can proceed to removing the keyboard bezel.
To do this, use a spudger to gently lift off the plastic edging as shown. There are small plastic hooks attaching the bezel to the keyboard.
Be careful not to rip any of the loops on the keyboard.
Now you are ready to pry the slider function from the back of the screen.
Remove the four screws. The bottom two screws are easier to see when the phone is slid about half open.
Again, use the spudger to pry around the edges loosening it until it comes apart.
There are several connectors still attaching these two pieces. Use the spudger to disconnect them on the screen.
