PS3 Dual Shock 3 Controler Charging Port Replacement
  1. PS3 Dual Shock 3 Controler Charging Port Replacement, Opening the Controller: step 1, image 1 of 1
    • Remove the 5 screws on the back of the controller.
    • The back housing of the controller can now be removed.
  2. PS3 Dual Shock 3 Controler Charging Port Replacement, Removing the Battery: step 2, image 1 of 1
    • Remove battery by unlatching the battery cables from battery connector clip.
  3. PS3 Dual Shock 3 Controler Charging Port Replacement, Freeing the Motherboard: step 3, image 1 of 1
    • Remove the two screws holding the motherboard to the front controller housing.
    • Next, remove the motherboard assembly from the controller housing. This is done by pressing in the clips on each side of the handle.
    • Freeing the motherboard from the housing will provide better access to the charging port.
  4. PS3 Dual Shock 3 Controler Charging Port Replacement, Preparing the Soldering Station: step 4, image 1 of 1
    • Prepare your station for the de-soldering of the charging port.
  5. PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: step 5, image 1 of 3 PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: step 5, image 2 of 3 PS3 Dual Shock 3 Controler Charging Port Replacement, Desoldering: step 5, image 3 of 3
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • To remove the defective charging port, you will need to de-solder the 9 pins holding the port to the motherboard.
    • First, used the desoldering pump to remove the solder from all 9 pins.
    • Then, use the desoldering wick to remove any excess solder left on the motherboard.
  6. PS3 Dual Shock 3 Controler Charging Port Replacement, Securing New Charging Port: step 6, image 1 of 1
    • After the charging port is removed, place the new charging port into position.
    • Hold the new port in place by using a clip to keep it from moving.
  7. PS3 Dual Shock 3 Controler Charging Port Replacement, Soldering The New Port: step 7, image 1 of 2 PS3 Dual Shock 3 Controler Charging Port Replacement, Soldering The New Port: step 7, image 2 of 2
    • Tin the soldering iron before soldering the connections. This is done by applying a small amount of solder to the tip of the hot iron.
    • Solder the 9 pin connections that connect the charging port to the motherboard.
To reassemble your device, follow instructions 1-3 in reverse order.
15 other people completed this guide.
Attak
595 Reputation
1 Guide authored
5 Comments
Shall DualShock3 require other than GND and VBUS for charging only
and does DS3 follow the standards of USB-miniB (eg: Data wires flipping).
Sony does have some fame to sacrifice standards over extra capability delivery.
JanLS - Reply
Would you guys happen to know, if my labeling is correct? I’m going to upgrade to USB-C.
https://imgur.com/a/RL68Yw5
Howling Beats - Reply
Thank you it's really useful, tips,
Alan - Reply
Thanks for this. But now there are four different USB charging ports, how to tell which one of them is suitable? kasynparts eg
kasynlife - Reply
please attak if you still using this platfrom i really need you to help me with a ps3 controller pins
Deyaa Alshapshiri - Reply
Past 24 Hours: 11
Past 7 Days: 59
Past 30 Days: 279
All Time: 17,245
