PRS Guitar Pickups Replacement
  1. PRS Guitar Pickups Replacement, Pickups: step 1, image 1 of 2 PRS Guitar Pickups Replacement, Pickups: step 1, image 2 of 2
    • Loosen all of the strings until they can be pulled out of the tuners.
    • Pull the strings through the bridge and out of the back side of the guitar.
  2. PRS Guitar Pickups Replacement: step 2, image 1 of 2 PRS Guitar Pickups Replacement: step 2, image 2 of 2
    • Using a Phillips head screwdriver, unscrew the back plate, revealing the pickup wiring.
  3. PRS Guitar Pickups Replacement: step 3, image 1 of 1
    • Take note of the wiring before desoldering the wires.
    • Begin desoldering the pickup wires.
    • Take care when soldering, as the tip is very hot.
  4. PRS Guitar Pickups Replacement: step 4, image 1 of 2 PRS Guitar Pickups Replacement: step 4, image 2 of 2
    • Turn the guitar face up and unscrew both of the pickups.
    • Take the pickups out of the guitar.
  5. PRS Guitar Pickups Replacement: step 5, image 1 of 2 PRS Guitar Pickups Replacement: step 5, image 2 of 2
    • Refer to the wiring arrangements you took note of as well as the wiring manual that came with your new pickups.
    • Run the new pickups back through the guitar with the wires guided through the back plate.
    • Carefully begin soldering the new pickup wires back together.
  6. PRS Guitar Pickups Replacement: step 6, image 1 of 1
    • This is a good opportunity to clean the guitar.
    • Begin restringing the guitar with new strings of your preference.
    • Using a string/wire cutter and cut excess strings from tuners.
Finish Line
Nathan Kevil
141 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 874
