PDP Afterglow Fener Battery Replacement
  1. PDP Afterglow Fener Battery Replacement, Battery: step 1, image 1 of 2 PDP Afterglow Fener Battery Replacement, Battery: step 1, image 2 of 2
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
  2. PDP Afterglow Fener Battery Replacement: step 2, image 1 of 2 PDP Afterglow Fener Battery Replacement: step 2, image 2 of 2
    • This shows what your device looks like on the inside behind the part that you just removed from the headset.
    • In the red square is the connection between the battery and the headset.
    • Gently pull the wires that are connected to the white part in the red square.
    • Now that your battery is not connected to anything you can take it out of the headset.
5 other people completed this guide.
Murat Terzi
210 Reputation
1 Guide authored
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Members
10 Guides authored
One Comment
Broke the headset while doing this “easy process” don’t listen to this method.
Daniel Sumida - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 23
All Time: 7,426
