Ovation Acoustic Guitar String Replacement
  1. Ovation Acoustic Guitar String Replacement, Guitar String: step 1, image 1 of 1
    • Place the guitar neck where you can easily identify the broken string.
  2. Ovation Acoustic Guitar String Replacement: step 2, image 1 of 2 Ovation Acoustic Guitar String Replacement: step 2, image 2 of 2
    • Place the guitar neck on an elevated surface (ex. bundle towels, pillow, etc.). Remove the string with a string winder until it is loose enough to pull out by hand.
  3. Ovation Acoustic Guitar String Replacement: step 3, image 1 of 1
    • Take the string out carefully and begin to pull the string out through the bridge which is at the lower end of the guitar.
  4. Ovation Acoustic Guitar String Replacement: step 4, image 1 of 2 Ovation Acoustic Guitar String Replacement: step 4, image 2 of 2
    • Once the string is removed, wipe down the guitar neck to prevent further oil buildup.
  5. Ovation Acoustic Guitar String Replacement: step 5, image 1 of 1
    • Layout the new guitar strings from biggest to smallest.
  6. Ovation Acoustic Guitar String Replacement: step 6, image 1 of 3 Ovation Acoustic Guitar String Replacement: step 6, image 2 of 3 Ovation Acoustic Guitar String Replacement: step 6, image 3 of 3
    • Pull the new string through the bridge until the stopper is flushed with the bridge.
  7. Ovation Acoustic Guitar String Replacement: step 7, image 1 of 2 Ovation Acoustic Guitar String Replacement: step 7, image 2 of 2
    • Position the skinny side of the string into the tuning peg. Allow enough excess string ( about 3 inches) so when the string is tightened, it will not break from being too tight or break from being too loose.
  8. Ovation Acoustic Guitar String Replacement: step 8, image 1 of 3 Ovation Acoustic Guitar String Replacement: step 8, image 2 of 3 Ovation Acoustic Guitar String Replacement: step 8, image 3 of 3
    • Loop the excess guitar string around the tuning peg and make sure the coil is being tuned downwards.
  9. Ovation Acoustic Guitar String Replacement: step 9, image 1 of 2 Ovation Acoustic Guitar String Replacement: step 9, image 2 of 2
    • Trim the excess string with pliers. Make sure it is cut as close to the tuning peg so it does not stick out.
Finish Line
Rachel Galvan
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 21
All Time: 713
