One Education Infinity Hinge Assembly Replacement
  1. One Education Infinity Hinge Assembly Replacement, Back Case: step 1, image 1 of 3 One Education Infinity Hinge Assembly Replacement, Back Case: step 1, image 2 of 3 One Education Infinity Hinge Assembly Replacement, Back Case: step 1, image 3 of 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Hinge Assembly Replacement: step 2, image 1 of 2 One Education Infinity Hinge Assembly Replacement: step 2, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Hinge Assembly Replacement: step 3, image 1 of 3 One Education Infinity Hinge Assembly Replacement: step 3, image 2 of 3 One Education Infinity Hinge Assembly Replacement: step 3, image 3 of 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Hinge Assembly Replacement, Battery: step 4, image 1 of 3 One Education Infinity Hinge Assembly Replacement, Battery: step 4, image 2 of 3 One Education Infinity Hinge Assembly Replacement, Battery: step 4, image 3 of 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Hinge Assembly Replacement: step 5, image 1 of 3 One Education Infinity Hinge Assembly Replacement: step 5, image 2 of 3 One Education Infinity Hinge Assembly Replacement: step 5, image 3 of 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Hinge Assembly Replacement, Upper Case: step 6, image 1 of 3 One Education Infinity Hinge Assembly Replacement, Upper Case: step 6, image 2 of 3 One Education Infinity Hinge Assembly Replacement, Upper Case: step 6, image 3 of 3
    • Flip open the laptop so that the screen is exposed.
    • We found it convenient to flip the laptop into tablet mode for added support.
    • Using a spudger, remove the six screw covers along the bezel of the screen.
  7. One Education Infinity Hinge Assembly Replacement: step 7, image 1 of 2 One Education Infinity Hinge Assembly Replacement: step 7, image 2 of 2
    • Remove the six 2.8 mm Phillips #00 screws along the bezel.
  8. One Education Infinity Hinge Assembly Replacement: step 8, image 1 of 3 One Education Infinity Hinge Assembly Replacement: step 8, image 2 of 3 One Education Infinity Hinge Assembly Replacement: step 8, image 3 of 3
    • Use the two tabs on the top edge of the screen to pry the case apart.
    • Once the two top clips have been disengaged, start to work your way around the rest of the screen.
  9. One Education Infinity Hinge Assembly Replacement: step 9, image 1 of 1
    • Once all the clips have been popped off, remove the upper case from the back of the display assembly.
    • You may want to close the laptop while disconnecting the hinge-side edge, as it will give you extra clearance for the upper case.
  10. Careful: steps 10-12 are sourced from a guide that's marked as in-progress.
    One Education Infinity Hinge Assembly Replacement, Upper Hinge Assembly: step 10, image 1 of 2 One Education Infinity Hinge Assembly Replacement, Upper Hinge Assembly: step 10, image 2 of 2
    • Remove the twelve 3.8 mm Phillips #00 screws from the hinge brackets extending along the height of the display.
  11. One Education Infinity Hinge Assembly Replacement: step 11, image 1 of 3 One Education Infinity Hinge Assembly Replacement: step 11, image 2 of 3 One Education Infinity Hinge Assembly Replacement: step 11, image 3 of 3
    • Peel back the four pieces of black tape.
    • Peel back the antenna cable boards off of the display hinges.
    • Peel off the silver tape from the display hinges.
  12. One Education Infinity Hinge Assembly Replacement: step 12, image 1 of 3 One Education Infinity Hinge Assembly Replacement: step 12, image 2 of 3 One Education Infinity Hinge Assembly Replacement: step 12, image 3 of 3
    • Lift up both hinges, ensuring that they clear all tape and wires.
  13. One Education Infinity Hinge Assembly Replacement, Hinge Assembly: step 13, image 1 of 3 One Education Infinity Hinge Assembly Replacement, Hinge Assembly: step 13, image 2 of 3 One Education Infinity Hinge Assembly Replacement, Hinge Assembly: step 13, image 3 of 3
    • Flip the laptop over to expose the open bottom case.
    • Remove the six 5.6 mm Phillips #00 screws from the hinge brackets on the bottom case.
  14. One Education Infinity Hinge Assembly Replacement: step 14, image 1 of 3 One Education Infinity Hinge Assembly Replacement: step 14, image 2 of 3 One Education Infinity Hinge Assembly Replacement: step 14, image 3 of 3
    • With the hinge still at a 90ยบ angle, pull the hinge assembly clear from the bottom case.
    • You will need to apply a modest amount of force to squeeze the edge of the case between the two mounting brackets of the hinge.
  15. One Education Infinity Hinge Assembly Replacement: step 15, image 1 of 3 One Education Infinity Hinge Assembly Replacement: step 15, image 2 of 3 One Education Infinity Hinge Assembly Replacement: step 15, image 3 of 3
    • Use a spudger to pop out a white plastic cable retaining bit from the hinge body.
    • Pull the cables out from the hinge body.
  16. One Education Infinity Hinge Assembly Replacement: step 16, image 1 of 1
    • Remove the hinge assembly from the device.
    • Repeat the same steps for the other side.
Austin Blakely
19,703 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,482 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 82
