One Education Infinity Heatsink Replacement
  1. One Education Infinity Heatsink Replacement, Back Case: step 1, image 1 of 3 One Education Infinity Heatsink Replacement, Back Case: step 1, image 2 of 3 One Education Infinity Heatsink Replacement, Back Case: step 1, image 3 of 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Heatsink Replacement: step 2, image 1 of 2 One Education Infinity Heatsink Replacement: step 2, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Heatsink Replacement: step 3, image 1 of 3 One Education Infinity Heatsink Replacement: step 3, image 2 of 3 One Education Infinity Heatsink Replacement: step 3, image 3 of 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Heatsink Replacement, Battery: step 4, image 1 of 3 One Education Infinity Heatsink Replacement, Battery: step 4, image 2 of 3 One Education Infinity Heatsink Replacement, Battery: step 4, image 3 of 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Heatsink Replacement: step 5, image 1 of 3 One Education Infinity Heatsink Replacement: step 5, image 2 of 3 One Education Infinity Heatsink Replacement: step 5, image 3 of 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Heatsink Replacement, Heatsink: step 6, image 1 of 2 One Education Infinity Heatsink Replacement, Heatsink: step 6, image 2 of 2
    • Remove the eight 2.8 mm screws from the heatsink with a Phillips #00 screwdriver.
  7. One Education Infinity Heatsink Replacement: step 7, image 1 of 3 One Education Infinity Heatsink Replacement: step 7, image 2 of 3 One Education Infinity Heatsink Replacement: step 7, image 3 of 3
    • Insert the tip of a spudger into the small gap along the right side edge of the heatsink and pry upward to free it from the clips.
  8. One Education Infinity Heatsink Replacement: step 8, image 1 of 1
    • Lift the heatsink up from the motherboard.
Austin Blakely
19,649 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
One Comment
Thanks for sharing. I will comeback here soon!
mabel goodrich - Reply
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 10
All Time: 198
