One Education Infinity Display Assembly Replacement
  1. One Education Infinity Display Assembly Replacement, Back Case: step 1, image 1 of 3 One Education Infinity Display Assembly Replacement, Back Case: step 1, image 2 of 3 One Education Infinity Display Assembly Replacement, Back Case: step 1, image 3 of 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Display Assembly Replacement: step 2, image 1 of 2 One Education Infinity Display Assembly Replacement: step 2, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Display Assembly Replacement: step 3, image 1 of 3 One Education Infinity Display Assembly Replacement: step 3, image 2 of 3 One Education Infinity Display Assembly Replacement: step 3, image 3 of 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Display Assembly Replacement, Battery: step 4, image 1 of 3 One Education Infinity Display Assembly Replacement, Battery: step 4, image 2 of 3 One Education Infinity Display Assembly Replacement, Battery: step 4, image 3 of 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Display Assembly Replacement: step 5, image 1 of 3 One Education Infinity Display Assembly Replacement: step 5, image 2 of 3 One Education Infinity Display Assembly Replacement: step 5, image 3 of 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Display Assembly Replacement, Upper Case: step 6, image 1 of 3 One Education Infinity Display Assembly Replacement, Upper Case: step 6, image 2 of 3 One Education Infinity Display Assembly Replacement, Upper Case: step 6, image 3 of 3
    • Flip open the laptop so that the screen is exposed.
    • We found it convenient to flip the laptop into tablet mode for added support.
    • Using a spudger, remove the six screw covers along the bezel of the screen.
  7. One Education Infinity Display Assembly Replacement: step 7, image 1 of 2 One Education Infinity Display Assembly Replacement: step 7, image 2 of 2
    • Remove the six 2.8 mm Phillips #00 screws along the bezel.
  8. One Education Infinity Display Assembly Replacement: step 8, image 1 of 3 One Education Infinity Display Assembly Replacement: step 8, image 2 of 3 One Education Infinity Display Assembly Replacement: step 8, image 3 of 3
    • Use the two tabs on the top edge of the screen to pry the case apart.
    • Once the two top clips have been disengaged, start to work your way around the rest of the screen.
  9. One Education Infinity Display Assembly Replacement: step 9, image 1 of 1
    • Once all the clips have been popped off, remove the upper case from the back of the display assembly.
    • You may want to close the laptop while disconnecting the hinge-side edge, as it will give you extra clearance for the upper case.
  10. Careful: steps 10-12 are sourced from a guide that's marked as in-progress.
    One Education Infinity Display Assembly Replacement, Upper Hinge Assembly: step 10, image 1 of 2 One Education Infinity Display Assembly Replacement, Upper Hinge Assembly: step 10, image 2 of 2
    • Remove the twelve 3.8 mm Phillips #00 screws from the hinge brackets extending along the height of the display.
  11. One Education Infinity Display Assembly Replacement: step 11, image 1 of 3 One Education Infinity Display Assembly Replacement: step 11, image 2 of 3 One Education Infinity Display Assembly Replacement: step 11, image 3 of 3
    • Peel back the four pieces of black tape.
    • Peel back the antenna cable boards off of the display hinges.
    • Peel off the silver tape from the display hinges.
  12. One Education Infinity Display Assembly Replacement: step 12, image 1 of 3 One Education Infinity Display Assembly Replacement: step 12, image 2 of 3 One Education Infinity Display Assembly Replacement: step 12, image 3 of 3
    • Lift up both hinges, ensuring that they clear all tape and wires.
  13. One Education Infinity Display Assembly Replacement, Display Assembly: step 13, image 1 of 3 One Education Infinity Display Assembly Replacement, Display Assembly: step 13, image 2 of 3 One Education Infinity Display Assembly Replacement, Display Assembly: step 13, image 3 of 3
    • Remove the first of the two display cables by peeling back the tape and pulling the cable out from the connector with your fingers.
  14. One Education Infinity Display Assembly Replacement: step 14, image 1 of 3 One Education Infinity Display Assembly Replacement: step 14, image 2 of 3 One Education Infinity Display Assembly Replacement: step 14, image 3 of 3
    • Peel up the second display cable starting from its base and then disconnect it by pulling it horizontally out of the connector.
  15. One Education Infinity Display Assembly Replacement: step 15, image 1 of 3 One Education Infinity Display Assembly Replacement: step 15, image 2 of 3 One Education Infinity Display Assembly Replacement: step 15, image 3 of 3
    • Peel back the last piece of tape holding down the left side antenna cable.
    • Ensure that both the left-hand display and antenna cables clear the cable guide just to the right of the left hinge.
  16. One Education Infinity Display Assembly Replacement: step 16, image 1 of 3 One Education Infinity Display Assembly Replacement: step 16, image 2 of 3 One Education Infinity Display Assembly Replacement: step 16, image 3 of 3
    • Peel back the black tape holding down the right display cable.
    • Ensure that both the right-hand display and antenna cables are free of the cable guide just to the left of the right hinge.
  17. One Education Infinity Display Assembly Replacement: step 17, image 1 of 3 One Education Infinity Display Assembly Replacement: step 17, image 2 of 3 One Education Infinity Display Assembly Replacement: step 17, image 3 of 3
    • Once the hinge brackets are both flipped up and the display and antenna cables are all free from the display assembly, slide the display assembly towards you and away from the rest of the device.
Austin Blakely
19,703 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,482 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 176
