Olympus TG-820 iHS Locking Mechanism Replacement
  1. Olympus TG-820 iHS Locking Mechanism Replacement, Battery: step 1, image 1 of 1
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Locking Mechanism Replacement: step 2, image 1 of 3 Olympus TG-820 iHS Locking Mechanism Replacement: step 2, image 2 of 3 Olympus TG-820 iHS Locking Mechanism Replacement: step 2, image 3 of 3
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Locking Mechanism Replacement: step 3, image 1 of 2 Olympus TG-820 iHS Locking Mechanism Replacement: step 3, image 2 of 2
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: step 4, image 1 of 3 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: step 4, image 2 of 3 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: step 4, image 3 of 3
    • Locate and remove the 4.7mm Phillips #000 screw on the back side of the battery compartment locking mechanism.
    • Locate and remove the 4.7mm Phillips #000 screw on the front side of the battery compartment locking mechanism.
  5. Olympus TG-820 iHS Locking Mechanism Replacement: step 5, image 1 of 1
    • Locate the two screws on the side of the battery compartment.
    • Remove the two 4.85mm Phillips #000 screws.
  6. Olympus TG-820 iHS Locking Mechanism Replacement: step 6, image 1 of 2 Olympus TG-820 iHS Locking Mechanism Replacement: step 6, image 2 of 2
    • Once all 4 screws are out, the back panel of the battery compartment will come off.
    • The entire battery compartment cover will also detach from the camera.
Larissa Knight
549 Reputation
5 Guides authored
Clemson, Team 7-2, Benson Spring 2016 Member of Clemson, Team 7-2, Benson Spring 2016
CLEM-BENSON-S16S7G2
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 14
All Time: 447
