OLPC XO-1.5 Speakers Replacement
  1. OLPC XO-1.5 Speakers Replacement, Battery: step 1, image 1 of 1
    • Place the laptop upside down with the handle away from you.
  2. OLPC XO-1.5 Speakers Replacement: step 2, image 1 of 1
    • Slide the tabs out, towards the green edges, to show the open lock symbol.
    • The right tab will stay in place, but the left tab must be held in position while you remove the battery.
  3. OLPC XO-1.5 Speakers Replacement: step 3, image 1 of 3 OLPC XO-1.5 Speakers Replacement: step 3, image 2 of 3 OLPC XO-1.5 Speakers Replacement: step 3, image 3 of 3
    • Lift the middle of the battery to remove it.
  4. OLPC XO-1.5 Speakers Replacement, Screen: step 4, image 1 of 3 OLPC XO-1.5 Speakers Replacement, Screen: step 4, image 2 of 3 OLPC XO-1.5 Speakers Replacement, Screen: step 4, image 3 of 3
    • Turn the laptop so it is resting on its bottom.
    • Open the laptop by rotating the green wings on the side up, then lifting the top half of the laptop.
    • Rotate the top half of the laptop about 90 degrees.
  5. OLPC XO-1.5 Speakers Replacement: step 5, image 1 of 2 OLPC XO-1.5 Speakers Replacement: step 5, image 2 of 2
    • Turn the laptop upside down, so you can see the screws on the bottom of the top half.
    • Remove the two 4mm screws with a Phillips #1 screwdriver.
    • Rotate the top half 180 degrees.
  6. OLPC XO-1.5 Speakers Replacement: step 6, image 1 of 1
    • Rotate the top of the laptop 90 degrees, so that it is facing you again.
    • Slide the green pieces off the device. They should come off easily.
  7. OLPC XO-1.5 Speakers Replacement: step 7, image 1 of 3 OLPC XO-1.5 Speakers Replacement: step 7, image 2 of 3 OLPC XO-1.5 Speakers Replacement: step 7, image 3 of 3
    • Pull down on the white screen cover. It does not require much force.
    • Remove the screen cover.
    • The game pad on the left sometimes falls during this step.
  8. OLPC XO-1.5 Speakers Replacement: step 8, image 1 of 2 OLPC XO-1.5 Speakers Replacement: step 8, image 2 of 2
    • Unscrew the four 7.62mm Phillips #1 screws on either side of the screen.
    • The screen is still connected by ribbon cables. You can damage the cables if you remove the screen before disconnecting the cables.
    • Move the screen down a little to expose the ribbon cables.
  9. OLPC XO-1.5 Speakers Replacement: step 9, image 1 of 3 OLPC XO-1.5 Speakers Replacement: step 9, image 2 of 3 OLPC XO-1.5 Speakers Replacement: step 9, image 3 of 3
    • Flip up the tab right under the middle top of the screen.
    • Pull the black ribbon cable out of the socket.
  10. OLPC XO-1.5 Speakers Replacement: step 10, image 1 of 2 OLPC XO-1.5 Speakers Replacement: step 10, image 2 of 2
    • Flip up the smaller tab under the left side of the screen.
    • Remove the small cable to separate the screen from the rest of the laptop.
    • Gently remove the screen.
  11. OLPC XO-1.5 Speakers Replacement, Wireless Card: step 11, image 1 of 1
    • Remove the four 4mm Phillips #1 screws that hold the top cover to the case.
  12. OLPC XO-1.5 Speakers Replacement: step 12, image 1 of 2 OLPC XO-1.5 Speakers Replacement: step 12, image 2 of 2
    • Close the lid and rotate the device 180°.
    • Press firmly on the top two corners of the outside cover. Then slide it down, away from the antennas.
  13. OLPC XO-1.5 Speakers Replacement: step 13, image 1 of 2 OLPC XO-1.5 Speakers Replacement: step 13, image 2 of 2
    • Remove the five 4mm Phillips #1 screws securing the EMI shield to the motherboard.
    • Gently lift up and remove the EMI shield.
  14. OLPC XO-1.5 Speakers Replacement: step 14, image 1 of 1
    • Gently remove the two antenna cables by lightly pulling the cable connectors up.
  15. OLPC XO-1.5 Speakers Replacement: step 15, image 1 of 2 OLPC XO-1.5 Speakers Replacement: step 15, image 2 of 2
    • Remove the two 5mm Phillips #1 screws holding the wireless card to the motherboard.
    • The wireless card will pop up at an angle.
  16. OLPC XO-1.5 Speakers Replacement: step 16, image 1 of 1
    • Remove the wireless card by gently lifting it out of the socket.
  17. OLPC XO-1.5 Speakers Replacement, Motherboard: step 17, image 1 of 3 OLPC XO-1.5 Speakers Replacement, Motherboard: step 17, image 2 of 3 OLPC XO-1.5 Speakers Replacement, Motherboard: step 17, image 3 of 3
    • Disconnect the five cables that connect the motherboard to the case by pulling them straight out of their sockets.
    • The motherboard is still attached to the case by a microphone cable. Do not remove the motherboard or you will damage the cable.
  18. OLPC XO-1.5 Speakers Replacement: step 18, image 1 of 1
    • Rotate the device 180° and open the lid.
    • Disconnect the microphone cable by pulling its connector straight out of its socket on the motherboard.
  19. OLPC XO-1.5 Speakers Replacement: step 19, image 1 of 3 OLPC XO-1.5 Speakers Replacement: step 19, image 2 of 3 OLPC XO-1.5 Speakers Replacement: step 19, image 3 of 3
    • Lift the left edge of the motherboard and remove it from the case.
    • Make sure that the microphone and headphone jack don't catch on the case as you are removing the motherboard.
  20. OLPC XO-1.5 Speakers Replacement, Speakers: step 20, image 1 of 3 OLPC XO-1.5 Speakers Replacement, Speakers: step 20, image 2 of 3 OLPC XO-1.5 Speakers Replacement, Speakers: step 20, image 3 of 3
    • Open the lid, rotate it 180° degrees, and close it again so the speakers are facing up.
    • Pull the speakers out and feed the cables through their holes in the case.
Wei Xia
518 Reputation
5 Guides authored
Cal Poly, Team 3-28, Amido Winter 2013 Member of Cal Poly, Team 3-28, Amido Winter 2013
CPSU-AMIDO-W13S3G28
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 13
All Time: 304
