Novatel MiFi 2200 Case Replacement
  1. Novatel MiFi 2200 Case Replacement, Battery: step 1, image 1 of 1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Case Replacement: step 2, image 1 of 1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Case Replacement, Case: step 3, image 1 of 1
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Case Replacement: step 4, image 1 of 1
    • Once the seal has been broken all the way around, open the cases using your hands.
2 other people completed this guide.
Justin Russo
196 Reputation
3 Guides authored
Cal Poly, Team 7-36, Maness Spring 2012 Member of Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Members
5 Guides authored
One Comment
If case gets damaged, is there a place to but the case
Snehraj Merchant - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,543
