Novatel MiFi 2200 Battery Replacement
  1. Novatel MiFi 2200 Battery Replacement, Battery: step 1, image 1 of 1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Battery Replacement: step 2, image 1 of 1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Battery Replacement: step 3, image 1 of 1
    • Insert the new battery into the battery slot.
    • Make sure to place the battery in with the white arrows facing inward.
  4. Novatel MiFi 2200 Battery Replacement: step 4, image 1 of 2 Novatel MiFi 2200 Battery Replacement: step 4, image 2 of 2
    • Re-install the rear cover by placing the inward end in it's slot.
    • Push down on the cover while sliding it into the slot to snap it back into place.
Charge your new battery and you are ready to use your Mifi again.
Carissah
147 Reputation
2 Guides authored
Cal Poly, Team 7-36, Maness Spring 2012 Member of Cal Poly, Team 7-36, Maness Spring 2012
CPSU-MANESS-S12S7G36
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,034
