Nortel Networks i2004 IP Speaker Replacement
  1. Nortel Networks i2004 IP Speaker Replacement, Back Cover: step 1, image 1 of 3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: step 1, image 2 of 3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: step 1, image 3 of 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Speaker Replacement: step 2, image 1 of 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Speaker Replacement: step 3, image 1 of 2 Nortel Networks i2004 IP Speaker Replacement: step 3, image 2 of 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Speaker Replacement: step 4, image 1 of 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Speaker Replacement: step 5, image 1 of 2 Nortel Networks i2004 IP Speaker Replacement: step 5, image 2 of 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Speaker Replacement, Speaker: step 6, image 1 of 1
    • Lift the speaker straight up.
    • The speaker may need to be slightly wiggled in order to loosen and remove.
  7. Nortel Networks i2004 IP Speaker Replacement: step 7, image 1 of 1
    • Cut the red and white wires as close to the speaker as possible.
    • Wire cutters are preferred, but normal scissors are fine too.
  8. Nortel Networks i2004 IP Speaker Replacement: step 8, image 1 of 2 Nortel Networks i2004 IP Speaker Replacement: step 8, image 2 of 2
    • Solder wires to new speaker.
Elizabeth
160 Reputation
3 Guides authored
Cal Poly, Team 10-35, Amido Winter 2012 Member of Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 11
All Time: 1,133
