Nokia N70 Back Camera Replacement
  1. Nokia N70 Back Camera Replacement, Battery: step 1, image 1 of 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Back Camera Replacement: step 2, image 1 of 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Back Camera Replacement: step 3, image 1 of 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Back Camera Replacement: step 4, image 1 of 1
    • Remove the battery from the phone.
  5. Nokia N70 Back Camera Replacement, Keypad: step 5, image 1 of 3 Nokia N70 Back Camera Replacement, Keypad: step 5, image 2 of 3 Nokia N70 Back Camera Replacement, Keypad: step 5, image 3 of 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Back Camera Replacement: step 6, image 1 of 3 Nokia N70 Back Camera Replacement: step 6, image 2 of 3 Nokia N70 Back Camera Replacement: step 6, image 3 of 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Back Camera Replacement, Back Camera: step 7, image 1 of 2 Nokia N70 Back Camera Replacement, Back Camera: step 7, image 2 of 2
    • Using T6 Torx screwdriver remove the six 15 mm torx screws.
  8. Nokia N70 Back Camera Replacement: step 8, image 1 of 3 Nokia N70 Back Camera Replacement: step 8, image 2 of 3 Nokia N70 Back Camera Replacement: step 8, image 3 of 3
    • Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
    • Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
  9. Nokia N70 Back Camera Replacement: step 9, image 1 of 3 Nokia N70 Back Camera Replacement: step 9, image 2 of 3 Nokia N70 Back Camera Replacement: step 9, image 3 of 3
    • Locate the rear circuit board by flipping over the front panel.
    • Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
    • Caution: Be careful when prying camera out of the slot for the connections are fragile.
5 other people completed this guide.
Justin
984 Reputation
5 Guides authored
Cal Poly, Team 6-2, Regan Fall 2011 Member of Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Members
10 Guides authored
One Comment
mon nokia n70 est mal camera alors quest -ce qu*on va faire
sidiahmed ahmed - Reply
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 19
All Time: 8,810
