Nokia N-gage Nem-4 Housing Replacement
  1. Nokia N-gage Nem-4 Housing Replacement, Housing: step 1, image 1 of 3 Nokia N-gage Nem-4 Housing Replacement, Housing: step 1, image 2 of 3 Nokia N-gage Nem-4 Housing Replacement, Housing: step 1, image 3 of 3
    • To take off the housing you need to turn the device upside down and push the release button down at the bottom of the phone and pull the cover down with your thumbs until you hear a click, and the cover should come free
  2. Nokia N-gage Nem-4 Housing Replacement, Undoing clips and lifting off bezel: step 2, image 1 of 3 Nokia N-gage Nem-4 Housing Replacement, Undoing clips and lifting off bezel: step 2, image 2 of 3 Nokia N-gage Nem-4 Housing Replacement, Undoing clips and lifting off bezel: step 2, image 3 of 3
    • To take off the front bezel you need to put your nails under the clips pictured and pry off the case
  3. Nokia N-gage Nem-4 Housing Replacement, Lifting off bezel: step 3, image 1 of 3 Nokia N-gage Nem-4 Housing Replacement, Lifting off bezel: step 3, image 2 of 3 Nokia N-gage Nem-4 Housing Replacement, Lifting off bezel: step 3, image 3 of 3
    • With the housing unclipped you should be able to lift it off.
  4. Nokia N-gage Nem-4 Housing Replacement, Removing button pads: step 4, image 1 of 2 Nokia N-gage Nem-4 Housing Replacement, Removing button pads: step 4, image 2 of 2
    • Lift off the buttons to reveal a bare contact pad. Now you have removed the housing !
ethancross2001
1 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 874
