Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement
Video Overview
  1. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: step 1, image 1 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: step 1, image 2 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: step 1, image 3 of 3
    • Switch off the phone and remove any SIM and memory card.
    • There are two tips T4 screws.
  2. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 2, image 1 of 2 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 2, image 2 of 2
    • Use a plastic tool to separate the back case.
    • Loudspeaker / Ringer
  3. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 3, image 1 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 3, image 2 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 3, image 3 of 3
    • Disconnect the Touchscreen and the LCD display flex cables.
    • The logic board is held by tho locking clips. Use plastic tools to remove it.
  4. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 4, image 1 of 1
    • Light proximity sensor
    • Earpiece
    • Audio jack connector
  5. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 5, image 1 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 5, image 2 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 5, image 3 of 3
    • Again use a plastic tool to separate the middle frame and the digitizer frame.
  6. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 6, image 1 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 6, image 2 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 6, image 3 of 3
    • This step is for those who wants to change the LCD display.
    • Use a sharp object to pick up a little the display.
    • Then with a spudger or a similar tool separate the display from the frame.
  7. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 7, image 1 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 7, image 2 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 7, image 3 of 3
    • Put some transparent tape on the broken glass.
    • Use hot air to warm and soften the old adhesive tape.
    • Start the separating from the middle, where the contact area is small.
  8. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 8, image 1 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 8, image 2 of 3 Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 8, image 3 of 3
    • Clean the frame
    • Clean the frame from the adhesive tape remnants and install a new one if your replacement part has come without adhesive tape.
    • Install the new touch screen and start with reassembling.
  9. Nokia Lumia 520 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 9, image 1 of 1
    • That's all.
    • Did you do it successfully?
12 other people completed this guide.
ZFix
191,341 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,541 Guides authored
One Comment
Toughees Telecom the most perfect place for <b>Lumia Screen Repair</b>
You don’t need to worry because we are with you at every step of <a href="http://www.tougheestelecom.in/nokia-lumi... title="Nokia Lumia Repair in Delhi">Lumia screen repair in Delhi</a>, as we understand what one feels when a customer has his <b>Screen Broken or Damaged</b>. You can call us and we will give you the best advice regarding <b>Lumia Screen Repair</b> in Delhi.
Sachin Seth - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 17
All Time: 7,512
