Nishiki Aero II Tire Removal
  1. Nishiki Aero II Tire Removal, Removing Road Bike Front Wheel: step 1, image 1 of 1
    • Turn the bike upside down.
  2. Nishiki Aero II Tire Removal: step 2, image 1 of 1
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Nishiki Aero II Tire Removal: step 3, image 1 of 2 Nishiki Aero II Tire Removal: step 3, image 2 of 2
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Nishiki Aero II Tire Removal: step 4, image 1 of 1
    • Follow the previous steps for the opposite side.
  5. Nishiki Aero II Tire Removal: step 5, image 1 of 1
    • Lift the wheel up from the fork.
  6. Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: step 6, image 1 of 2 Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: step 6, image 2 of 2
    • Unscrew the cap from the air valve.
    • Release the tire's air by pressing a thin object on the center pin of the valve.
    • A hex wrench or any blunt object can be used.
  7. Nishiki Aero II Tire Removal: step 7, image 1 of 3 Nishiki Aero II Tire Removal: step 7, image 2 of 3 Nishiki Aero II Tire Removal: step 7, image 3 of 3
    • Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
    • Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
    • Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
  8. Nishiki Aero II Tire Removal: step 8, image 1 of 2 Nishiki Aero II Tire Removal: step 8, image 2 of 2
    • Repeat with an additional tire lever five inches away from the other.
  9. Nishiki Aero II Tire Removal: step 9, image 1 of 3 Nishiki Aero II Tire Removal: step 9, image 2 of 3 Nishiki Aero II Tire Removal: step 9, image 3 of 3
    • Repeat with a third tire lever farther around the tire.
    • Alternate lifting the second and third levers until the tire comes partway off.
  10. Nishiki Aero II Tire Removal: step 10, image 1 of 3 Nishiki Aero II Tire Removal: step 10, image 2 of 3 Nishiki Aero II Tire Removal: step 10, image 3 of 3
    • Wedge the tire off of the other rim with the tire levers.
    • Pull the air valve from its hole in the rim to completely remove the tire.
Tobias Elder
113 Reputation
7 Guides authored
Cal Poly, Team 21-53, Johann Spring 2013 Member of Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 14
All Time: 1,219
