Image #1
Add Note Edit Step 9  ¶
  • Remove the two 5 mm Phillips screws above the controller ports.
Image #1
Add Note Edit Step 10  ¶
  • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
Image #1
Add Note Edit Step 11  ¶
  • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Wing screw
Image #1
Add Note Edit Step 12  ¶
  • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
Image #1
Add Note Edit Step 13  ¶
  • Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
Image #1
Add Note Edit Step 14  ¶
  • Lift the outer case straight up off the body of the Wii.
Image #1 Image #2
Add Note Edit Step 15 — DVD Drive  ¶
  • Remove the small Phillips screw securing the battery door to the bottom panel.
  • This screw is captive to the battery door.
  • Pull the battery door out of the Wii.
Image #1
Add Note Edit Step 16  ¶
  • Remove the 8.2 mm Tri-Wing screw that was hidden beneath the battery door.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Metal Spudger
$2.95 · 50+ In stock
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
