Wii U GamePad Outer Case Replacement
  1. Wii U GamePad Outer Case Replacement, Battery: step 1, image 1 of 2 Wii U GamePad Outer Case Replacement, Battery: step 1, image 2 of 2
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Wii U GamePad Outer Case Replacement: step 2, image 1 of 3 Wii U GamePad Outer Case Replacement: step 2, image 2 of 3 Wii U GamePad Outer Case Replacement: step 2, image 3 of 3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Wii U GamePad Outer Case Replacement, Outer Case: step 3, image 1 of 3 Wii U GamePad Outer Case Replacement, Outer Case: step 3, image 2 of 3 Wii U GamePad Outer Case Replacement, Outer Case: step 3, image 3 of 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Wii U GamePad Outer Case Replacement: step 4, image 1 of 2 Wii U GamePad Outer Case Replacement: step 4, image 2 of 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
11 other people completed this guide.
Kim Arre
4,918 Reputation
8 Guides authored
Cal Poly, Team 17-20, Forte Winter 2013 Member of Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Members
38 Guides authored
2 Comments
This is either incomplete or mistitled - it is a currently a back plate replacement guide.
At the conclusion of this how-to/walkthrough, most of the GamePad's hardware is still attached to the front plate, one half of the outer case.
Elijah - Reply
and the front?
Raul Kim Diego - Reply
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 116
All Time: 14,589
