Nintendo Game Boy Advance SP Buttons Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Nintendo Game Boy Advance SP Buttons Replacement, Buttons: step 1, image 1 of 1
    • Game Boy Advance SP (Nintendo 2002)
  2. Nintendo Game Boy Advance SP Buttons Replacement: step 2, image 1 of 3 Nintendo Game Boy Advance SP Buttons Replacement: step 2, image 2 of 3 Nintendo Game Boy Advance SP Buttons Replacement: step 2, image 3 of 3
    • Using a Phillips 000 driver, loosen the screw securing the battery compartment.
    • Using a metal spudger, gently lift the battery compartment by placing the edge just under the screw. The screw will come off with the cover as it has a washer holding it in place.
    • Remove battery using a plastic spudger or fingernail.
  3. Nintendo Game Boy Advance SP Buttons Replacement: step 3, image 1 of 3 Nintendo Game Boy Advance SP Buttons Replacement: step 3, image 2 of 3 Nintendo Game Boy Advance SP Buttons Replacement: step 3, image 3 of 3
    • Back cover contains 4 Gold Tri-Wing #0 screws (Red circle), and 2 Silver Tri-Wing #0 Screws (Yellow circle).
    • Remove screws and lift back cover off giving access to motherboard.
    • Motherboard is secured by 3 Phillips #0 screws.
    • Triggers L&R (Orange box), and Power Switch Piece (Yellow box) are found affixed to the rear cover.
  4. Nintendo Game Boy Advance SP Buttons Replacement: step 4, image 1 of 1
    • Flip the motherboard over very carefully as not to damage the display ribbon.
    • You now have access to the device speaker and buttons.
  5. Nintendo Game Boy Advance SP Buttons Replacement: step 5, image 1 of 3 Nintendo Game Boy Advance SP Buttons Replacement: step 5, image 2 of 3 Nintendo Game Boy Advance SP Buttons Replacement: step 5, image 3 of 3
    • Carefully using fingers, detatch display ribbon from its socket. This ribbon is especially hard to remove due to the angle in which you'll need to remove it.
    • You can now access the motherboard and the input buttons freely.
10 other people completed this guide.
abeleko
553 Reputation
1 Guide authored
3 Comments
It appears that the tri-wing screw heads are not really Y0 - certain kits that have Y0 bits, like the Harbor Freight Electronics Repair Kit, did not work for me. I wonder if it's 00, or something metric. If you're shopping, beware of interchangeable bits that are too short or shafts that are too fat, as well.
AySz88 - Reply
Oh, the "Y1" screwdriver that the page "recommends" (sells) in the display at the bottom of the guide is definitely wrong as well. Since Y0 was too large, Y1 definitely wouldn't fit.
I ended up getting a 5-pack of special-made screwdrivers (all of the same one).
These work fine, even on a couple of screws that I stripped a little while trying the aforementioned Y0.
I suspect it's some standard size, but I have no way to tell for sure. The markings on it are "360/(Y)x50" but the only standard thing I can decipher from that is that the "x50" might refer to the 5 cm shaft length. :/
Cheapest price I found for a single driver is about $2-3, or $6 for the 5-pack I got.
AySz88 -
Apply WD40 with a cotton bud on the motherboard buttons can fix them. I just fixed my 'A' button by this way. I already fixed a mouse button with a drop of wd40 years ago, and it still work perfectly today.
Nicolas - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 6,611
