Nintendo Entertainment System cartridge cover replacement
  1. Nintendo Entertainment System cartridge cover replacement, Removing housing: step 1, image 1 of 2 Nintendo Entertainment System cartridge cover replacement, Removing housing: step 1, image 2 of 2
    • Remove the six 13.50mm PH2 screws from the base plate.
    • The screws are countersunk 40mm into the base plate.
    • Now take off the upper part of the housing.
  2. Nintendo Entertainment System cartridge cover replacement, Cartridge cover: step 2, image 1 of 3 Nintendo Entertainment System cartridge cover replacement, Cartridge cover: step 2, image 2 of 3 Nintendo Entertainment System cartridge cover replacement, Cartridge cover: step 2, image 3 of 3
    • Take the top housing and turn it over.
    • Remove the four 7,80mm flathead screws.
    • Remove both metal clips.
    • If the flap does not stay open properly, you can bend the clips with pliers.
  3. Nintendo Entertainment System cartridge cover replacement, Cover Flap: step 3, image 1 of 3 Nintendo Entertainment System cartridge cover replacement, Cover Flap: step 3, image 2 of 3 Nintendo Entertainment System cartridge cover replacement, Cover Flap: step 3, image 3 of 3
    • Pull the front black cap off upwards.
    • Now lift the flap out at an angle.
    • The new flap can now be inserted.
Work the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
TimedIn
981 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 60
All Time: 1,819
