Nintendo 3DS Circle Pad Joystick Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Nintendo 3DS Circle Pad Joystick Replacement, Circle Pad Joystick: step 1, image 1 of 1
    • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
  2. Nintendo 3DS Circle Pad Joystick Replacement: step 2, image 1 of 3 Nintendo 3DS Circle Pad Joystick Replacement: step 2, image 2 of 3 Nintendo 3DS Circle Pad Joystick Replacement: step 2, image 3 of 3
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
  3. Nintendo 3DS Circle Pad Joystick Replacement: step 3, image 1 of 3 Nintendo 3DS Circle Pad Joystick Replacement: step 3, image 2 of 3 Nintendo 3DS Circle Pad Joystick Replacement: step 3, image 3 of 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
  4. Nintendo 3DS Circle Pad Joystick Replacement: step 4, image 1 of 2 Nintendo 3DS Circle Pad Joystick Replacement: step 4, image 2 of 2
    • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
    • Use a spudger or screwdriver to lift the pads up and remove them from the device.
David Hodson
150,526 Reputation
127 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 11
All Time: 372
