Nikon Coolpix S9050 Menu Wheel and OK Button Replacement
  1. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: step 1, image 1 of 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: step 1, image 2 of 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement, Menu Wheel and OK Button: step 1, image 3 of 3
    • Remove the screws. There are two on each side, and four on the bottom. The black screws are 3.2 mm Phillips #000. The silver screws are also 3.2 mm Phillips #000.
  2. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: step 2, image 1 of 1
    • Remove the screen housing and trim piece.
  3. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: step 3, image 1 of 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: step 3, image 2 of 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: step 3, image 3 of 3
    • Press down and pull the Menu Wheel/OK Button panel towards the screen. This will release the panel from the slots.
  4. Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: step 4, image 1 of 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: step 4, image 2 of 3 Nikon Coolpix S9050 Menu Wheel and OK Button Replacement: step 4, image 3 of 3
    • Lift up on the black plastic tab(zero insertion force connector-ZIF) and gently pull the panel out to detach the ribbon cable from the camera body.
Catrionna Bruce
205 Reputation
2 Guides authored
IUPUI, Team S3-G3, Harley Fall 2018 Member of IUPUI, Team S3-G3, Harley Fall 2018
IUPUI-HARLEY-F18S3G3
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 475
