Nikon Coolpix S800c Motherboard Replacement Guide
  1. Nikon Coolpix S800c Motherboard Replacement Guide, Back Panel/Touch Screen: step 1, image 1 of 2 Nikon Coolpix S800c Motherboard Replacement Guide, Back Panel/Touch Screen: step 1, image 2 of 2
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Motherboard Replacement Guide: step 2, image 1 of 2 Nikon Coolpix S800c Motherboard Replacement Guide: step 2, image 2 of 2
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
  3. Nikon Coolpix S800c Motherboard Replacement Guide, Motherboard: step 3, image 1 of 1
    • Unscrew all 6 visible screws that secure the motherboard into place using a Phillips head screwdriver (found in iFixit tool kit).
  4. Nikon Coolpix S800c Motherboard Replacement Guide: step 4, image 1 of 1
    • Pull the shown panel off of the motherboard to expose the Image sensor connection
  5. Nikon Coolpix S800c Motherboard Replacement Guide: step 5, image 1 of 1
    • Lift tab up to remove the Image sensor connection strip.
  6. Nikon Coolpix S800c Motherboard Replacement Guide: step 6, image 1 of 3 Nikon Coolpix S800c Motherboard Replacement Guide: step 6, image 2 of 3 Nikon Coolpix S800c Motherboard Replacement Guide: step 6, image 3 of 3
    • Pull the gray panels back to allow the hidden micro usb and hdmi insert connectors to come free.
    • Use a Metal Spudger to help with the process to get these connectors free from the frame.
  7. Nikon Coolpix S800c Motherboard Replacement Guide: step 7, image 1 of 2 Nikon Coolpix S800c Motherboard Replacement Guide: step 7, image 2 of 2
    • Using a Metal Spudger, lift the motherboard up from the body of the camera.
  8. Nikon Coolpix S800c Motherboard Replacement Guide: step 8, image 1 of 2 Nikon Coolpix S800c Motherboard Replacement Guide: step 8, image 2 of 2
    • Pull the motherboard off of the main body of the camera.
Soldered wires attaching the motherboard to the camera body will need to be disconnected at the motherboard-end and the new wires on the replacement motherboard will need to be soldered on. To reassemble your device, follow these instructions in reverse order.
Kenneth Huynh
133 Reputation
1 Guide authored
Baylor, Team S2-G6, Johnson Spring 2018 Member of Baylor, Team S2-G6, Johnson Spring 2018
BU-JOHNSON-S18S2G6
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 234
