Nikon Coolpix S5300 Outer Casing Replacement
  1. Nikon Coolpix S5300  Outer Casing Replacement, Battery: step 1, image 1 of 1
    • Turn the camera upside down and locate the battery compartment.
    • Slide the compartment open following the direction of the arrow.
  2. Nikon Coolpix S5300  Outer Casing Replacement: step 2, image 1 of 1
    • Press the orange release button to release and remove the battery.
    • Replace or insert battery in it's respective terminals
  3. Nikon Coolpix S5300  Outer Casing Replacement, Outer Casing: step 3, image 1 of 3 Nikon Coolpix S5300  Outer Casing Replacement, Outer Casing: step 3, image 2 of 3 Nikon Coolpix S5300  Outer Casing Replacement, Outer Casing: step 3, image 3 of 3
    • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
    • Using the same screwdriver, remove the 2 screws on the side of the camera.
    • Remove the 2 screws from the other side of the camera.
    • One of the screws is under the I/O port cover.
  4. Nikon Coolpix S5300  Outer Casing Replacement: step 4, image 1 of 3 Nikon Coolpix S5300  Outer Casing Replacement: step 4, image 2 of 3 Nikon Coolpix S5300  Outer Casing Replacement: step 4, image 3 of 3
    • Use the plastic opening tool to carefully separate the cover from the camera.
    • Work the plastic opening tool around all the edges of the front plate.
    • Pull the purple plastic cover off gently from the screen.
  5. Nikon Coolpix S5300  Outer Casing Replacement: step 5, image 1 of 3 Nikon Coolpix S5300  Outer Casing Replacement: step 5, image 2 of 3 Nikon Coolpix S5300  Outer Casing Replacement: step 5, image 3 of 3
    • Turn the camera over so the LCD screen is facing you.
    • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
  6. Nikon Coolpix S5300  Outer Casing Replacement: step 6, image 1 of 2 Nikon Coolpix S5300  Outer Casing Replacement: step 6, image 2 of 2
    • Be careful to keep track of little pieces of the outside casing.
  7. Nikon Coolpix S5300  Outer Casing Replacement: step 7, image 1 of 2 Nikon Coolpix S5300  Outer Casing Replacement: step 7, image 2 of 2
    • Carefully remove the top button casing by pulling it away from main camera.
Riordan McCole
307 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 184
