Nikon Coolpix S4100 External Casing Replacement
  1. Nikon Coolpix S4100 External Casing Replacement, External Casing: step 1, image 1 of 3 Nikon Coolpix S4100 External Casing Replacement, External Casing: step 1, image 2 of 3 Nikon Coolpix S4100 External Casing Replacement, External Casing: step 1, image 3 of 3
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
  2. Nikon Coolpix S4100 External Casing Replacement: step 2, image 1 of 1
    • Remove the black casing on the back of the camera that runs around the LCD screen.
  3. Nikon Coolpix S4100 External Casing Replacement: step 3, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
  4. Nikon Coolpix S4100 External Casing Replacement: step 4, image 1 of 3 Nikon Coolpix S4100 External Casing Replacement: step 4, image 2 of 3 Nikon Coolpix S4100 External Casing Replacement: step 4, image 3 of 3
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
  5. Nikon Coolpix S4100 External Casing Replacement: step 5, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
  6. Nikon Coolpix S4100 External Casing Replacement: step 6, image 1 of 2 Nikon Coolpix S4100 External Casing Replacement: step 6, image 2 of 2
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
  7. Nikon Coolpix S4100 External Casing Replacement: step 7, image 1 of 3 Nikon Coolpix S4100 External Casing Replacement: step 7, image 2 of 3 Nikon Coolpix S4100 External Casing Replacement: step 7, image 3 of 3
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
  8. Nikon Coolpix S4100 External Casing Replacement: step 8, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
  9. Nikon Coolpix S4100 External Casing Replacement: step 9, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
  10. Nikon Coolpix S4100 External Casing Replacement: step 10, image 1 of 1
    • Remove the remaining side shell casing.
  11. Nikon Coolpix S4100 External Casing Replacement: step 11, image 1 of 1
    • Remove the top shell casing.
2 other people completed this guide.
Matthew Willis
586 Reputation
4 Guides authored
Baylor, Team 4-2, Williams Fall 2015 Member of Baylor, Team 4-2, Williams Fall 2015
BU-WILLIAMS-F15S4G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 940
