Nikon Coolpix P90 Eyepiece Replacement
  1. Nikon Coolpix P90 Eyepiece Replacement, Camera Base: step 1, image 1 of 3 Nikon Coolpix P90 Eyepiece Replacement, Camera Base: step 1, image 2 of 3 Nikon Coolpix P90 Eyepiece Replacement, Camera Base: step 1, image 3 of 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 Eyepiece Replacement, Eyepiece: step 2, image 1 of 3 Nikon Coolpix P90 Eyepiece Replacement, Eyepiece: step 2, image 2 of 3 Nikon Coolpix P90 Eyepiece Replacement, Eyepiece: step 2, image 3 of 3
    • Use a Phillips #000 Precision Screwdriver for all of the following steps.
    • On the bottom side of the camera, unscrew both 4.5 mm screws holding the bottom into place, per image 1.
    • On the right side of the camera, unscrew both 4.5 mm screws holding the side into place, per image 2.
    • On the right side of the camera, unscrew the 4.5 mm screw underneath the A/V flap, per image 2.
    • On the top side of the camera, unscrew the 4.0 mm screw on the left-side wrist strap loop, per image 3.
  3. Nikon Coolpix P90 Eyepiece Replacement: step 3, image 1 of 2 Nikon Coolpix P90 Eyepiece Replacement: step 3, image 2 of 2
    • Use a Phillips #000 Precision Screwdriver for the following step.
    • Lift up the LCD screen to reveal the two screws.
    • Unscrew the two 3.0 mm screws that hold the arm in place, per image 2.
  4. Nikon Coolpix P90 Eyepiece Replacement: step 4, image 1 of 1
    • Carefully lift up the back cover from the rear side of the camera.
    • Possible Device Damage: Do NOT completely remove the back cover from the camera yet. There is a data transfer ribbon connecting the LCD screen to the motherboard, per image 1.
  5. Nikon Coolpix P90 Eyepiece Replacement: step 5, image 1 of 2 Nikon Coolpix P90 Eyepiece Replacement: step 5, image 2 of 2
    • Press your finger on the top of the ribbon latch and pull it down and toward you to open the safety latch and free the ribbon, per image 1.
    • Possible Device Damage: Be careful when releasing the safety latch because it is fragile and may break easily.
    • Slide the ribbon out from its socket.
    • It is now safe to completely remove the back cover from the camera.
  6. Nikon Coolpix P90 Eyepiece Replacement: step 6, image 1 of 2 Nikon Coolpix P90 Eyepiece Replacement: step 6, image 2 of 2
    • On the back side of the camera, unscrew the seven 4.0 mm screws that connect the metal plate to the motherboard, per image 1.
    • On the top side or the camera, unscrew the three 4.0 mm screws that connect the metal hinges to the camera body, per image 2.
  7. Nikon Coolpix P90 Eyepiece Replacement: step 7, image 1 of 1
    • Carefully lift the metal backing from the motherboard.
    • Possible Device Damage: Do NOT completely remove the metal backing yet. There is a data transfer ribbon connecting the metal backing to the motherboard, per image 1.
  8. Nikon Coolpix P90 Eyepiece Replacement: step 8, image 1 of 2 Nikon Coolpix P90 Eyepiece Replacement: step 8, image 2 of 2
    • Press your finger on the top of the latch and pull it down and towards you to open the safety latch and free the ribbon, per image 1.
    • It is now safe to completely remove the metal backing from the camera.
  9. Nikon Coolpix P90 Eyepiece Replacement: step 9, image 1 of 1
    • Unscrew the 3.0 mm screw that holds the eyepiece in place, per image 1.
  10. Nikon Coolpix P90 Eyepiece Replacement: step 10, image 1 of 1
    • Possible Device Damage: Do NOT completely remove the eyepiece yet. There is a data transfer ribbon connecting the eyepiece to the motherboard, per image 1.
    • Using a plastic opening tool, carefully unlatch the safety latch that holds the eyepiece data transfer ribbon in place.
  11. Nikon Coolpix P90 Eyepiece Replacement: step 11, image 1 of 1
    • Remove the eyepiece from the camera by gently pulling it back.
    • Replace the old eyepiece with a new eyepiece.
    • Congratulations, the repair is finished!
Elizabeth Kamine
655 Reputation
6 Guides authored
Cal Poly, Team 20-14, Maness Winter 2015 Member of Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 Members
7 Guides authored
One Comment
Excellent Illustrative photographs and instructions
Charles Ikerman - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 20
All Time: 824
