Nikon Coolpix L840 Lanyard Ring Replacement
  1. Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: step 1, image 1 of 3 Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: step 1, image 2 of 3 Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: step 1, image 3 of 3
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Lanyard Ring Replacement: step 2, image 1 of 1
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Lanyard Ring Replacement: step 3, image 1 of 2 Nikon Coolpix L840 Lanyard Ring Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
  4. Nikon Coolpix L840 Lanyard Ring Replacement, Lanyard Ring: step 4, image 1 of 2 Nikon Coolpix L840 Lanyard Ring Replacement, Lanyard Ring: step 4, image 2 of 2
    • Identify lanyard ring.
    • Unscrew the 4 mm black screw with a Philips 000.
  5. Nikon Coolpix L840 Lanyard Ring Replacement: step 5, image 1 of 2 Nikon Coolpix L840 Lanyard Ring Replacement: step 5, image 2 of 2
    • Insert a metal spludger (or another sturdy tool with a thin tip) into the hole of the lanyard ring and lift the ring upwards and out of the camera.
Abraham Lozano
595 Reputation
4 Guides authored
Cal Poly, Team 1-11, Maness Spring 2016 Member of Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 12
All Time: 632
