Nikon Coolpix L820 Settings Buttons Replacement
  1. Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: step 1, image 1 of 3 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: step 1, image 2 of 3 Nikon Coolpix L820 Settings Buttons Replacement, Settings Buttons: step 1, image 3 of 3
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
  2. Nikon Coolpix L820 Settings Buttons Replacement: step 2, image 1 of 2 Nikon Coolpix L820 Settings Buttons Replacement: step 2, image 2 of 2
    • Remove the front top Phillips screw with the screwdriver.
    • Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Unscrew the four Phillips screws with the screwdriver.
  3. Nikon Coolpix L820 Settings Buttons Replacement: step 3, image 1 of 3 Nikon Coolpix L820 Settings Buttons Replacement: step 3, image 2 of 3 Nikon Coolpix L820 Settings Buttons Replacement: step 3, image 3 of 3
    • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
    • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
    • Once the rear housing is separated, the settings buttons will be accessible for replacement.
Marc
430 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 18
All Time: 1,284
