Nikon Coolpix B700 Back Frame Assembly Replacement
  1. Nikon Coolpix B700 Back Frame Assembly Replacement, Back Frame Assembly: step 1, image 1 of 1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Back Frame Assembly Replacement: step 2, image 1 of 1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Back Frame Assembly Replacement: step 3, image 1 of 2 Nikon Coolpix B700 Back Frame Assembly Replacement: step 3, image 2 of 2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Back Frame Assembly Replacement: step 4, image 1 of 1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Back Frame Assembly Replacement: step 5, image 1 of 3 Nikon Coolpix B700 Back Frame Assembly Replacement: step 5, image 2 of 3 Nikon Coolpix B700 Back Frame Assembly Replacement: step 5, image 3 of 3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Back Frame Assembly Replacement: step 6, image 1 of 1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Back Frame Assembly Replacement: step 7, image 1 of 2 Nikon Coolpix B700 Back Frame Assembly Replacement: step 7, image 2 of 2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
Finish Line
2 other people completed this guide.
0 Comments
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 11
All Time: 660
