Introduction
This guide will show you how to remove and replace the rear case of the Nikon Coolpix A900.
You may want to replace the rear case of the camera if it gets dropped, or develops a crack.
In most cases, you will need to remove the rear case to access other components that need to be replaced.
Before you get started, make sure that you have several containers for small parts so you can stay organized.
Orient the camera upside down, with the lens facing away from you.
Remove the two 3mm Phillips #00 screws from the right.
Remove the two 3.4mm Phillips #00 screws from the left.
