Nikon CoolPix S5 Plastic LCD Screen Cover Replacement
  1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Back Cover: step 1, image 1 of 1
    • Remove the wristlet by untying the strap.
  2. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: step 2, image 1 of 1
    • Open the SD/Battery cover.
  3. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: step 3, image 1 of 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: step 3, image 2 of 2
    • Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
  4. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: step 4, image 1 of 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: step 4, image 2 of 2
    • Remove the side paneling of the camera by prying it off with your hands.
  5. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: step 5, image 1 of 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: step 5, image 2 of 2
    • Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
    • Repeat the removal of the two screws on the other side of the camera.
  6. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: step 6, image 1 of 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: step 6, image 2 of 2
    • Separate the back faceplate from the rest of the camera.
  7. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: step 7, image 1 of 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: step 7, image 2 of 2
    • Press lightly on the outer surface of the plastic LCD screen cover in each corner.
    • The plastic LCD screen cover should pop out of the back plate.
2 other people completed this guide.
Josh Miller
87 Reputation
3 Guides authored
Clemson, Team 12-5, Benson Spring 2013 Member of Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 410
