Nikon 1 J5 Back Case Replacement
  1. Nikon 1 J5 Back Case Replacement, Remove Micro SD card and Battery: step 1, image 1 of 1
    • Remove Micro SD card and Battery
  2. Nikon 1 J5 Back Case Replacement: step 2, image 1 of 3 Nikon 1 J5 Back Case Replacement: step 2, image 2 of 3 Nikon 1 J5 Back Case Replacement: step 2, image 3 of 3
    • Remove 2 screws
    • Open plastic LCD connector cover
    • Lift FPC connector latch
    • Detach LCD FPC
  3. Nikon 1 J5 Back Case Replacement: step 3, image 1 of 3 Nikon 1 J5 Back Case Replacement: step 3, image 2 of 3 Nikon 1 J5 Back Case Replacement: step 3, image 3 of 3
    • Remove 4 screws
    • Remove LCD module
  4. Nikon 1 J5 Back Case Replacement, Back Case: step 4, image 1 of 1
    • WARNING!!! DO NOT TOUCH THESE Solder joints!!! High Voltage up to 300V..
    • Or discharge the flash condenser first, as per "Main PCB replace guide"
    • Remove 3 screws
  5. Nikon 1 J5 Back Case Replacement: step 5, image 1 of 3 Nikon 1 J5 Back Case Replacement: step 5, image 2 of 3 Nikon 1 J5 Back Case Replacement: step 5, image 3 of 3
    • Left side, in connector bay, remove 2 screws.
    • Bottom, reomve 2 screws
    • Right side, remove 1 screw
  6. Nikon 1 J5 Back Case Replacement: step 6, image 1 of 1
    • Peel here and remove 1 screw within.
  7. Nikon 1 J5 Back Case Replacement: step 7, image 1 of 2 Nikon 1 J5 Back Case Replacement: step 7, image 2 of 2
    • Pop open back case and remove it from body.
Terrance
6,368 Reputation
17 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 158
