Nest Cam Outdoor S Internal Camera Replacement
  1. Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: step 1, image 1 of 2 Nest Cam Outdoor S Internal Camera Replacement, Plastic Camera Cover: step 1, image 2 of 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Internal Camera Replacement: step 2, image 1 of 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Internal Camera Replacement: step 3, image 1 of 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Internal Camera Replacement: step 4, image 1 of 2 Nest Cam Outdoor S Internal Camera Replacement: step 4, image 2 of 2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Internal Camera Replacement, Internal Camera: step 5, image 1 of 1
    • Pry the plastic cover away from the motherboard at the plastic clips using a spudger.
  6. Nest Cam Outdoor S Internal Camera Replacement: step 6, image 1 of 1
    • Remove the four mounting screws from the motherboard.
  7. Nest Cam Outdoor S Internal Camera Replacement: step 7, image 1 of 1
    • Disconnect the yellow camera cable from the motherboard.
    • Remove the camera from the device.
2 other people completed this guide.
Skylar DeVoe
235 Reputation
2 Guides authored
2 Comments
Can you replace the corn to the actual camera
Cathy Willis - Reply
Can you replace the corn to actual camera
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 32
All Time: 1,670
