Nest Cam Outdoor S Battery Replacement
  1. Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: step 1, image 1 of 2 Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: step 1, image 2 of 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Battery Replacement: step 2, image 1 of 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Battery Replacement: step 3, image 1 of 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Battery Replacement: step 4, image 1 of 2 Nest Cam Outdoor S Battery Replacement: step 4, image 2 of 2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Battery Replacement, Battery: step 5, image 1 of 2 Nest Cam Outdoor S Battery Replacement, Battery: step 5, image 2 of 2
    • Wedge a nylon spudger between the white outer shell and the battery.
    • Slowly pull the battery away from the plastic camera cover.
    • The battery is only held on with glue.
Phelix Gaudette
275 Reputation
2 Guides authored
2 Comments
Do you have the P/N of the battery??
Richard K Yabuki - Reply
Where to buy a replacement battery?
Ted McKenna - Reply
Past 24 Hours: 7
Past 7 Days: 56
Past 30 Days: 285
All Time: 6,303
