Motorola i850 LCD Screen Replacement
  1. Motorola i850 LCD Screen Replacement, LCD Board: step 1, image 1 of 1
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Motorola i850 LCD Screen Replacement: step 2, image 1 of 2 Motorola i850 LCD Screen Replacement: step 2, image 2 of 2
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Motorola i850 LCD Screen Replacement: step 3, image 1 of 1
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Motorola i850 LCD Screen Replacement: step 4, image 1 of 1
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Motorola i850 LCD Screen Replacement: step 5, image 1 of 1
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Motorola i850 LCD Screen Replacement: step 6, image 1 of 1
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Motorola i850 LCD Screen Replacement: step 7, image 1 of 1
    • Completely remove the outer casing from the phone.
  8. Motorola i850 LCD Screen Replacement: step 8, image 1 of 2 Motorola i850 LCD Screen Replacement: step 8, image 2 of 2
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Motorola i850 LCD Screen Replacement: step 9, image 1 of 1
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Motorola i850 LCD Screen Replacement: step 10, image 1 of 1
    • Prop out the LCD board from the phone using your fingertips.
  11. Motorola i850 LCD Screen Replacement: step 11, image 1 of 2 Motorola i850 LCD Screen Replacement: step 11, image 2 of 2
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
  12. Motorola i850 LCD Screen Replacement, LCD Screen: step 12, image 1 of 1
    • Firmly detach the gold strip using a Tweezer.
  13. Motorola i850 LCD Screen Replacement: step 13, image 1 of 1
    • Prop out the LCD screen using a Small Flathead Screwdriver.
  14. Motorola i850 LCD Screen Replacement: step 14, image 1 of 3 Motorola i850 LCD Screen Replacement: step 14, image 2 of 3 Motorola i850 LCD Screen Replacement: step 14, image 3 of 3
    • Remove the LCD screen from the LCD board.
Andrew Aw
1 Reputation
2 Guides authored
Cal Poly, Team 34-56, Forte Spring 2010 Member of Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 2,108
