Motorola W315 Antenna Replacement
  1. Motorola W315 Antenna Replacement, Battery: step 1, image 1 of 1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Antenna Replacement: step 3, image 1 of 1
    • Insert the new battery.
  3. Motorola W315 Antenna Replacement, Rear Case: step 4, image 1 of 1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Antenna Replacement: step 5, image 1 of 3 Motorola W315 Antenna Replacement: step 5, image 2 of 3 Motorola W315 Antenna Replacement: step 5, image 3 of 3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Motorola W315 Antenna Replacement, Antenna: step 6, image 1 of 1
    • Gently twist the antenna in a counter-clockwise direction to unscrew it.
  6. Motorola W315 Antenna Replacement: step 7, image 1 of 2 Motorola W315 Antenna Replacement: step 7, image 2 of 2
    • Pull the antenna out through the hole in the top of the frame and set it aside.
  7. Motorola W315 Antenna Replacement: step 8, image 1 of 3 Motorola W315 Antenna Replacement: step 8, image 2 of 3 Motorola W315 Antenna Replacement: step 8, image 3 of 3
    • Using a plastic opening tool, lift and remove the antenna casing.
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Justin Scott
501 Reputation
5 Guides authored
Clemson, Team 6-3, Benson Spring 2014 Member of Clemson, Team 6-3, Benson Spring 2014
CLEM-BENSON-S14S6G3
3 Members
18 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 211
