Motorola V60s Speakers Replacement
  1. Motorola V60s Speakers Replacement, Battery: step 1, image 1 of 3 Motorola V60s Speakers Replacement, Battery: step 1, image 2 of 3 Motorola V60s Speakers Replacement, Battery: step 1, image 3 of 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Speakers Replacement: step 2, image 1 of 2 Motorola V60s Speakers Replacement: step 2, image 2 of 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Speakers Replacement, Speakers: step 3, image 1 of 2 Motorola V60s Speakers Replacement, Speakers: step 3, image 2 of 2
    • Remove the four screws using a T6 Torx screwdriver.
    • Top screws are silver and short while bottom screws are black and longer.
  4. Motorola V60s Speakers Replacement: step 4, image 1 of 2 Motorola V60s Speakers Replacement: step 4, image 2 of 2
    • Insert an iFixit opening tool into phone in between back panel and body of phone.
    • Carefully pry up until back panel comes off, then remove with hands and set aside.
  5. Motorola V60s Speakers Replacement: step 5, image 1 of 1
    • Carefully insert an iFixit opening tool between the speaker and phone chassis. Slowly pry until speakers come out.
    • Be careful on this step; it may take some time.
Eric Freeman
10 Reputation
7 Guides authored
Cal Poly, Team 8-48, Regan Winter 2010 Member of Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 15
All Time: 1,567
