Motorola V276 Main LCD Screen Replacement
  1. Motorola V276 Main LCD Screen Replacement, Front panel/ Screen Logic Board: step 1, image 1 of 1
    • Using the plastic opening tool, pry off the top faceplate.
    • Place the tool in the small crack that runs along the side of the phone and pry.
  2. Motorola V276 Main LCD Screen Replacement: step 2, image 1 of 1
    • Using the T6 Torx Screwdriver remove all 4 small screws.
  3. Motorola V276 Main LCD Screen Replacement: step 3, image 1 of 1
    • Remove silver plate from phone.
  4. Motorola V276 Main LCD Screen Replacement: step 4, image 1 of 1
    • Using the spudger remove the plastic camera casing
  5. Motorola V276 Main LCD Screen Replacement: step 5, image 1 of 1
    • Using the iPod Opening Tool remove the yellow flex cable from the green logic board.
  6. Motorola V276 Main LCD Screen Replacement: step 6, image 1 of 1
    • Use Spudger or hands to detach flex cable from front screen logic board
  7. Motorola V276 Main LCD Screen Replacement, Main LCD Screen: step 7, image 1 of 2 Motorola V276 Main LCD Screen Replacement, Main LCD Screen: step 7, image 2 of 2
    • Using spudger remove the LCD screen from the green logic board.
Cecilia
1 Reputation
3 Guides authored
Cal Poly, Team 27-96, Amido Spring 2010 Member of Cal Poly, Team 27-96, Amido Spring 2010
CPSU-AMIDO-S10S27G96
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 1,334
