Motorola Razr V3c Speaker (CDMA) Replacement
  1. Motorola Razr V3c Speaker (CDMA) Replacement, Battery (CDMA): step 1, image 1 of 3 Motorola Razr V3c Speaker (CDMA) Replacement, Battery (CDMA): step 1, image 2 of 3 Motorola Razr V3c Speaker (CDMA) Replacement, Battery (CDMA): step 1, image 3 of 3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Speaker (CDMA) Replacement: step 2, image 1 of 2 Motorola Razr V3c Speaker (CDMA) Replacement: step 2, image 2 of 2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Speaker (CDMA) Replacement, Speaker (CDMA): step 3, image 1 of 1
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Speaker (CDMA) Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Speaker (CDMA) Replacement: step 5, image 1 of 1
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Speaker (CDMA) Replacement: step 6, image 1 of 2 Motorola Razr V3c Speaker (CDMA) Replacement: step 6, image 2 of 2
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Speaker (CDMA) Replacement: step 7, image 1 of 2 Motorola Razr V3c Speaker (CDMA) Replacement: step 7, image 2 of 2
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Speaker (CDMA) Replacement: step 8, image 1 of 1
    • Pull out the speaker.
Joshua Ruehlig
506 Reputation
4 Guides authored
Cal Poly, Team 11-4, Forte Winter 2010 Member of Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 5,424
