Motorola RAZR2 v9m Camera Replacement
  1. Motorola RAZR2 v9m Camera Replacement, Battery: step 1, image 1 of 2 Motorola RAZR2 v9m Camera Replacement, Battery: step 1, image 2 of 2
    • Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
  2. Motorola RAZR2 v9m Camera Replacement: step 2, image 1 of 3 Motorola RAZR2 v9m Camera Replacement: step 2, image 2 of 3 Motorola RAZR2 v9m Camera Replacement: step 2, image 3 of 3
    • Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
    • The rear panel uses four small hooks to hold it in place. If the panel will not easily pull away, slide the panel more toward the hinge.
  3. Motorola RAZR2 v9m Camera Replacement: step 3, image 1 of 2 Motorola RAZR2 v9m Camera Replacement: step 3, image 2 of 2
    • Gently pull the white plastic tab to lift the battery away from the RAZR2.
    • The white plastic tab is attached to the phone. Only pull it enough to expose the edges of the battery.
  4. Motorola RAZR2 v9m Camera Replacement: step 4, image 1 of 2 Motorola RAZR2 v9m Camera Replacement: step 4, image 2 of 2
    • To remove the battery, grasp its edges pull away from the phone.
    • When installing a new battery, be sure the metal contacts on the phone line up with the ones on the battery.
  5. Motorola RAZR2 v9m Camera Replacement, Camera: step 5, image 1 of 3 Motorola RAZR2 v9m Camera Replacement, Camera: step 5, image 2 of 3 Motorola RAZR2 v9m Camera Replacement, Camera: step 5, image 3 of 3
    • Flip open the RAZR2 with the keypad and main LCD facing you.
    • Insert a spudger into the small gap above the plastic screen.
    • Gently pry the screen away from the phone.
  6. Motorola RAZR2 v9m Camera Replacement: step 6, image 1 of 3 Motorola RAZR2 v9m Camera Replacement: step 6, image 2 of 3 Motorola RAZR2 v9m Camera Replacement: step 6, image 3 of 3
    • The plastic screen is held in place by adhesive. Run the spudger along both sides of the screen to separate it from the RAZR2.
    • Lift the screen away from the phone.
  7. Motorola RAZR2 v9m Camera Replacement: step 7, image 1 of 2 Motorola RAZR2 v9m Camera Replacement: step 7, image 2 of 2
    • Remove the four 2-mm T5 Torx screws
  8. Motorola RAZR2 v9m Camera Replacement: step 8, image 1 of 2 Motorola RAZR2 v9m Camera Replacement: step 8, image 2 of 2
    • Use a plastic opening tool to pry the top end of the metal frame away from the RAZR2.
  9. Motorola RAZR2 v9m Camera Replacement: step 9, image 1 of 3 Motorola RAZR2 v9m Camera Replacement: step 9, image 2 of 3 Motorola RAZR2 v9m Camera Replacement: step 9, image 3 of 3
    • Insert a plastic opening tool under the metal frame at the hinge of the RAZR2.
    • Gently pry the hinge portion of the metal frame away from the phone.
    • The metal frame is latched to the phone on the corner closest to the clear and end call buttons. Pry this part of the frame away last.
  10. Motorola RAZR2 v9m Camera Replacement: step 10, image 1 of 3 Motorola RAZR2 v9m Camera Replacement: step 10, image 2 of 3 Motorola RAZR2 v9m Camera Replacement: step 10, image 3 of 3
    • Lift the frame away from the phone.
    • When reassembling, insert the latch on the metal frame into the phone before inserting any other part of the frame.
  11. Motorola RAZR2 v9m Camera Replacement: step 11, image 1 of 3 Motorola RAZR2 v9m Camera Replacement: step 11, image 2 of 3 Motorola RAZR2 v9m Camera Replacement: step 11, image 3 of 3
    • Use the plastic opening tool to gently pry the motherboard cable out of its socket.
  12. Motorola RAZR2 v9m Camera Replacement: step 12, image 1 of 3 Motorola RAZR2 v9m Camera Replacement: step 12, image 2 of 3 Motorola RAZR2 v9m Camera Replacement: step 12, image 3 of 3
    • Use the plastic opening tool to gently pry the LCD cable out of its socket.
  13. Motorola RAZR2 v9m Camera Replacement: step 13, image 1 of 3 Motorola RAZR2 v9m Camera Replacement: step 13, image 2 of 3 Motorola RAZR2 v9m Camera Replacement: step 13, image 3 of 3
    • Use the plastic opening tool to gently pry the camera cable out of its socket.
  14. Motorola RAZR2 v9m Camera Replacement: step 14, image 1 of 3 Motorola RAZR2 v9m Camera Replacement: step 14, image 2 of 3 Motorola RAZR2 v9m Camera Replacement: step 14, image 3 of 3
    • Use a plastic opening tool to gently pry the camera assembly away from the RAZR2.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,008
