Motorola MBP667CONNECT Speaker Replacement
  1. Motorola MBP667CONNECT Speaker Replacement, Camera Stand: step 1, image 1 of 2 Motorola MBP667CONNECT Speaker Replacement, Camera Stand: step 1, image 2 of 2
    • Remove two 5 mm Phillips #1 screws from the bottom of the camera stand.
  2. Motorola MBP667CONNECT Speaker Replacement: step 2, image 1 of 1
    • Use a nylon spudger to remove the casing.
  3. Motorola MBP667CONNECT Speaker Replacement: step 3, image 1 of 1
    • Remove the two 5 mm Phillips #1 screws attached to the black plastic under the casing.
  4. Motorola MBP667CONNECT Speaker Replacement: step 4, image 1 of 2 Motorola MBP667CONNECT Speaker Replacement: step 4, image 2 of 2
    • Remove the black circular plastic part.
  5. Motorola MBP667CONNECT Speaker Replacement: step 5, image 1 of 1
    • Remove the white plastic wire housing beneath the black plastic.
  6. Motorola MBP667CONNECT Speaker Replacement: step 6, image 1 of 2 Motorola MBP667CONNECT Speaker Replacement: step 6, image 2 of 2
    • Now, remove the bottom of the stand by pulling it from the camera.
  7. Motorola MBP667CONNECT Speaker Replacement, Speaker: step 7, image 1 of 3 Motorola MBP667CONNECT Speaker Replacement, Speaker: step 7, image 2 of 3 Motorola MBP667CONNECT Speaker Replacement, Speaker: step 7, image 3 of 3
    • Remove the Phillips #1 screws on the back of the device.
    • Use a nylon spudger to remove the casing. This will separate the frontside of the camera from the backside.
  8. Motorola MBP667CONNECT Speaker Replacement: step 8, image 1 of 2 Motorola MBP667CONNECT Speaker Replacement: step 8, image 2 of 2
    • Now locate the brackets by the speaker on the frontside of the camera and use the metal spudger to carefully disconnect from casing.
    • Continue to use the metal spudger to carefully disconnect the remaining brackets from the casing.
  9. Motorola MBP667CONNECT Speaker Replacement: step 9, image 1 of 2 Motorola MBP667CONNECT Speaker Replacement: step 9, image 2 of 2
    • Using the soldering iron, desolder the speaker wires that are attached to the circuit board.
    • Use caution while handling the soldering iron. This tool gets very hot!
    • After desoldering the speaker wires, remove the wires from the circuit board.
    • Thread the wires from the new speaker wires through the holes in the circuit board. Using the soldering iron, re-solder the wires to the circuit board.
Kyle Kramer
255 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 171
