Motorola MBP667CONNECT Camera Stand Replacement
  1. Motorola MBP667CONNECT Camera Stand Replacement, Camera Stand: step 1, image 1 of 2 Motorola MBP667CONNECT Camera Stand Replacement, Camera Stand: step 1, image 2 of 2
    • Remove two 5 mm Phillips #1 screws from the bottom of the camera stand.
  2. Motorola MBP667CONNECT Camera Stand Replacement: step 2, image 1 of 1
    • Use a nylon spudger to remove the casing.
  3. Motorola MBP667CONNECT Camera Stand Replacement: step 3, image 1 of 1
    • Remove the two 5 mm Phillips #1 screws attached to the black plastic under the casing.
  4. Motorola MBP667CONNECT Camera Stand Replacement: step 4, image 1 of 2 Motorola MBP667CONNECT Camera Stand Replacement: step 4, image 2 of 2
    • Remove the black circular plastic part.
  5. Motorola MBP667CONNECT Camera Stand Replacement: step 5, image 1 of 1
    • Remove the white plastic wire housing beneath the black plastic.
  6. Motorola MBP667CONNECT Camera Stand Replacement: step 6, image 1 of 2 Motorola MBP667CONNECT Camera Stand Replacement: step 6, image 2 of 2
    • Now, remove the bottom of the stand by pulling it from the camera.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 565
